How to get GeoJSON properties to appear in popup on feature click in Openlayers3?
I have a map with a base layer and a geojson cluster layer. I want to be able to click an individual feature on the map and have the contents of the properties be displayed in a popup. I currently have just the position working in the popup but I would like to get information like the name of the feature and various other things. This is my code that gets me a location popup:
var element = document.getElementById('popup');var popup = new ol.Overlay({element: element,positioning: 'bottom-center',stopEvent: false});map.addOverlay(popup);// display popup on clickmap.on('click', function(evt) {var feature = map.forEachFeatureAtPixel(evt.pixel, function(feature, layer) { return feature; });if (feature) {var geometry = feature.getGeometry();var coord = geometry.getCoordinates();popup.setPosition(coord);coord = ol.proj.transform(coord, 'EPSG:3857', 'EPSG:4326');$(element).popover({ 'placement': 'top', 'html': true, 'content': ('Location:
'+coord)});$(element).popover('show');} else {$(element).popover('destroy');}});This works fine but I would like to get the other properties. I have tried feature.get('property here') instead of feature.getGeometry(); and geometry.getCoordinates(); but that made it so the popup never appeared and the only thing I was getting in firebug was an error in the ol.js b.slice() is not a function. So basically my question is: Is there a clear cut way to display all GeoJSON properties of a feature in a popup? I got my popup using the null island example here
And here is an example JSON feature:
{"type":"FeatureCollection","features":[{"type":"Feature","geometry":{"type":"Point","coordinates":[0.13138000,49.475577]},"properties":{"name":"227006760","speed":"55","Nav_Status":"5"}}]}Thanks for the help!
