How to get arcpy to work with Anaconda?
I am trying to follow the step-by-step directions in the answer to "how to separate Python installation with ArcGIS" but cannot find the path file, DTBGGP64.pth, in C:\Python27\ArcGIS10.2\Lib\site-packages.
Has someone has faced a similar issue?
I am wondering if there is a workaround by including a path file that tells Anaconda where arcpy is installed? I tried to create a .pth file containing the following text:
# .pth file for arcpyC:\Program Files (x86)\ArcGIS\Desktop10.2\bin C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpyC:\Program Files (x86)\ArcGIS\Desktop10.2\Scriptsand saved it to C:\Anaconda\Lib\site-packages (that is, if this is indeed where all the packages are saved) but I get the following error:
Traceback (most recent call last): File "", line 1, in File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\__init__.py", line 21, in from arcpy.geoprocessing import gp File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\__init__.py", line 14, in from _base import * File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 14, in import arcgisscriptingImportError: DLL load failed: %1 is not a valid Win32 application.I am running conda 3.7-py27 on a windows 7 (64bit) platform. Anaconda is installed in C:\Anaconda and ArcMap is installed in C:\ArcGIS\Desktop10.2. Is there an alternative solution to get arcpy to work with Anaconda? I just want to be able to run my scripts from Powershell.
