I am using ArcGIS for Desktop 10.1 Basic without extensions. How can I convert a metes and bounds description such as below?
For example, 47 degrees, is there a way you can convert the degrees minutes seconds while using CONTROL G (Direction / Length)? I switched in the Editing Options the direction type to Quadrant Bearing and Direction Units to DMS.
SW, SOUTH 0 DEGREES 02' WEST, 110.51 FEET; SOUTH 47 DEGREES 52' WEST, 246 FEET; SOUTH 74 DEGREES 41' WEST, 167.25 FEET; NORTH 75 DEGREES 19' WEST, 274.85 FEET; NORTH 41 DEGREES 49' WEST, 339.45 FEET; NORTH 89 DEGREES 14' WEST, 42.60 FEET; AND EAST 876.75 FEET TO BEGINNING, CONTAINING APPROXIMATELY 4 ACRES,LESS 4 ACRES IN THE NE CORNER OF SAID SW/4
