How to edit shapefile name written to attribute table in QGIS?
I have adapted some QGIS pythonscript code from a previous question to assign the filename of a shapefile to that shapefiles attribute table as a prelude to joining multiple shapefiles together (the SAGA plugin isn't working for me). It looks like this:
##Add Filename to Table=name ##Input_Folder=Folder ##nomodeler import os import glob from os.path import expanduser home = expanduser("~") # Input Folder #path_dir = home + "/Documents/GIS Data/TEMP/" + Folder_Name path_dir = Input_Folder #This takes the input from the parameter #Check that the folder "results" exists and if not create it if not os.path.exists(path_dir + "/Results"): os.makedirs(path_dir + "/Results") progress.setInfo("Setting save location") # Set the save location to the folder "results" path_res = path_dir + "/Results" progress.setInfo("Starting file processing") def run(): # Set working directory and search for all shapefiles then run algorithm os.chdir(path_dir ) for fname in glob.glob("*.shp"): formula = "'" + fname + "'" processing.runalg("qgis:fieldcalculator", fname, 'Filename', 2, 50, 0, True, formula , path_res + "/"+ fname) # Paths of the shapefiles in the Result folder with list comprehension output = [shp for shp in glob.glob(path_res + "*.shp")] run() progress.setInfo("Finished") Currently it adds the whole filename to the attribute table. How would I alter the formula to trim the filename, for example to extract the OS tile code of a shapefile called "HP_SomeText.shp"?
