How to delete feature from ArcGIS secured REST end in Android
I am trying to delete feature from secured ArcGIS feature layer using apply edits by passing a graphic array as input, but it is showing me the error
unable to complete operation, no adds, updates or deletes were specified.
Also, if I pass the same graphic for update operation then it is being updated successfully.
Following is the code snippet:
Map graphicAttributes = new HashMap(); graphicAttributes.put("OBJECTID", 65); Graphic mfinalGraphic = new Graphic(null, null, graphicAttributes); arcGISFeatureLayer.applyEdits(null, new Graphic[]{mfinalGraphic}, null, new CallbackListener() { @Override public void onCallback(final FeatureEditResult[][] featureEditResults) { runOnUiThread(new Runnable() { @Override public void run() { Toast.makeText(MainActivity.this, "Successfully deleted", Toast.LENGTH_LONG).show(); } } ); } @Override public void onError(final Throwable throwable) { runOnUiThread(new Runnable() { @Override public void run() { Toast.makeText(MainActivity.this, "Failed to delete", Toast.LENGTH_LONG).show(); } }); } }); While tracking on fiddler, I am getting the following request:
f=json&deletes=&token=BY26ICX0-KN....
The problem is at rest end if I pass only the object id in f=json&deletes=7&token=BY26ICX0-KN.... then it is getting deleted successfully.But there is no way of passing only object id in applyEdits for delete part in Android API. As applyEdits expects only Graphics.
