How to delete duplicate rows where multiple values are duplicated?
I have a feature class where there are multiple values duplicated in a row, i.e. SRNumber and RESOLUTION_CODE. I would like to delete all rows where my SRNumber and RESOLUTION_CODE are found in multiple rows. I have got a good start with this script, everything works aside from actually deleting the rows. How can I fix this so that my duplicate rows are deleted?
So if SRNumber = 1-23456 and Resolution_Code = 'A' and appears twice, I would like to delete one.
import arcpy in_table = r"ServiceRequest.DBO.SO_Dead_Animal" fields = ["NumberCYLA","RESOLUTION_CODE"] #replace with own curStrings = arcpy.da.SearchCursor(in_table,fields,"NumberCYLA is not null") stringsKeysList = [] numbersValuesList = [] tableDict = {} for row in curStrings: print row[0],row[1] stringsKeysList.append(row[0]) del curStrings uniqueStringsList = list(set(stringsKeysList)) #only unique values from Strings field for uniqueString in uniqueStringsList: emptyTempValues = [] curValues = arcpy.da.SearchCursor(in_table,fields,"""NumberCYLA = '{0}'""".format(str(uniqueString))) for row in curValues: print row[1] emptyTempValues.append(row[1]) uniqueEmptyTempValues = list(set(emptyTempValues)) tableDict[uniqueString] = uniqueEmptyTempValues print tableDict #a dictionary with string:values #{u'String_2': [-4, -2], #u'String_3': [None, -3], #u'String_56': [-1], #u'String_1': [-1], #u'String78': [-1]} rowsToDelete = [k for k, v in tableDict.iteritems() if v == [-1]] #find which rows to delete print "list: ", rowsToDelete stringRows = "," updRows = stringRows.join(rowsToDelete) updRows = updRows.replace(",","','") print updRows #update the string to be used with proper syntax in where clause where_clause = """NumberCYLA in ('{0}')""".format(updRows) upd_cur = arcpy.da.UpdateCursor(in_table,fields,where_clause) for row in upd_cur: print row[0],row[1] del rowsToDelete
