How to delete ArcGIS Project created using ArcGIS Pro?
I have deleted a few ArcGIS Projects, created using ArcGIS Pro, by using Windows Explorer to delete the folder that contains them.
However, I thought that, as long as the project (not the current project) was not already open somewhere else, then it may have been possible to use the Project pane to delete it.
I added a folder connection in the Project pane to a folder above the project that I wanted to delete but when I right-clicked on the project there is no Delete option offered (and hitting the Delete key while it is highlighted does nothing either).
Is the recommended way to delete an ArcGIS Project (created using ArcGIS Pro) simply to use Windows Explorer to delete its folder?
