How to define a coordinate reference system with rotation in GeoServer?
I am using GeoServer and have a layer in EPSG:900913 ("Google Mercator").
I need to "rotate" the map around certain point (say, 1500000, 7000000) by certain degree (say, 30 degrees clockwise). How could I define such a coordinate system based on EPSG:900913?
GeoServer's angle vendor option does not work for my purposes as I need to tile the map later on.
So as far as I understand this, my only option is to define an own coordinate system. For GeoServer I'd need to define it in WKT form. The configuration seems to be straightforward, but I have a difficulty defining my rotated CRS in WKT.
I'd be grateful help or pointers on how to apply a rotation around certain point onto a CRS like Google Mercator:
PROJCS["WGS84 / Google Mercator", GEOGCS["WGS 84", DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Longitude", EAST], AXIS["Latitude", NORTH], AUTHORITY["EPSG","4326"]], PROJECTION["Mercator_1SP"], PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","900913"]]My questions, specifically:
  • How to write a WKT which transform an existing CRS? My guess would be that I need a new PROJCS wrapping an existing one and adding a PROJECTION clause.
  • How would I found out the projection id (like Mercator_1SP above) and the required parameters (the PARAMETER clauses)?
  • Can I "reference" EPSG:900913 in CRS WKT instead of copy-pasting the whole PROJCS clause?
