I want to create a custom import routine that can read/import an sdr file. The sdr files will contain information the surveyor has picked up when completing an as-built. The data will likely contain info on sewer lines and manholes etc... I need to read the file and convert it to more readable form extracting XY coordinates.
I am new to sdr files and I have looked online but as yet cannot find anywhere that explains the different parts to the file.
The file is an ascii text file but the text is a bit cryptic to me. Can someone help me understand how to read the file?
I have included the file here and I don't expect someone to go line by line but if you could grab a section and say what it is doing and how to get usable information from it? What I need is Cartesian coordinates and an understanding of what data the file has recorded.
I hope I have explained enough to give you an understanding of what I am after.
Here is the file I was given as an example:
00NMSDR20 V03-05 19-May-15 13:16 113111 10NM18TH 19MAY15
13CPSea level crn: N 13CPC and R crn: N 13CPAtmos crn: N 06NM1.00000000 13OOCurrent view
13TS19-May-15 11:14
13JS10000
13TS19-May-15 11:15
08KI0001805555.619372578.52060.2780000IS 1
08KI1000805506.488372503.18362.6710000CHK2 13TS19-May-15 11:30 01NM:SET3030R3
035653 00000031 0.00000000 13PCReflector type: Sheet
13PCP.C. mm Applied: 0.000
02TP0001805555.619372578.52060.27800001.51300000IS 1
13PCReflector type: Prism
13PCP.C. mm Applied: -30.000
13TLEDM tol. error: Pt: 1000 0.029
13TLV.obs tol. error: Pt: 1000 0-01'24"
07TP00011000236.889632236.889722 03NM1.50300000 09F10001100090.001998388.5055555236.889722CHK2
09F10001000290.001998388.5058333236.890000IS 2
13PCReflector type: None
03NM0.00000000 09F10001100133.159003595.372500023.9275000B CL
13TS19-May-15 11:40
09F10001100223.081999796.484722215.8830555CL
09F10001100314.637995698.2472222359.583333CL
09F10001100412.278006499.0144444348.680000CL
09F10001100541.929008194.756944428.9430555B LLL
09F10001100633.127995495.406666625.3286111LLL
09F10001100723.073007296.526388817.2686111LLL
09F10001100814.671002098.25000000.02972222LLL
09F10001100942.545005094.700000025.9958333B LLR
09F10001101033.449000095.343055522.5869444LLR
09F10001101123.333993896.433888815.3083333LLR
09F10001101214.734000698.2108333359.618333LLR
09F10001101341.842994894.901666633.5125000B ELL
09F10001101432.460007895.629722230.7866666ELL
09F10001101522.093007596.983055524.6222222ELL
09F10001101614.125997199.069444412.8650000ELL
09F10001101710.1820014101.169722359.147777ELL
09F10001101842.080001494.726666627.8213888ESI
09F10001101942.081000594.733888828.3241666ESI
09F10001102042.490999094.716666628.8533333ESI
09F10001102144.815001194.580277729.4322222ESI
09F10001102246.794001694.473055529.8577777ESI
03NM1.94500000 09F10001102346.803993392.083611129.7355555ESI
09F10001102446.886992292.071944427.4763888ESI
09F10001102543.960998592.069444427.0383333ESI
09F10001102642.305000992.069444427.2433333ESI
09F10001102741.612000292.390833335.5294444B ESL
09F10001102841.510999392.286666635.8852777B TKL
09F10001102931.509001093.195277735.2919444B XNG
13TS19-May-15 11:51
03NM1.44500000 09F10001103031.393994893.120555536.8958333XNG
09F10001103127.606005293.229166636.4225000XNG
09F10001103227.439008393.278055534.0844444XNG
09F10001103326.797998393.272222234.7058333PP
09F10001103430.565005393.343888833.8358333ESL
09F10001103526.800995893.299166633.7438888TKL
09F10001103619.977002293.492500031.5122222TKL
09F10001103719.957001893.491944431.5183333B XNG
09F10001103821.144998293.632777731.0744444ESL
09F10001103920.142000793.456111133.5150000XNG
09F10001104020.134007393.456111133.5183333B FPP
09F10001104123.932005693.366111135.3563888XNG
09F10001104224.239004993.361388833.2975000XNG
09F10001104324.238005793.361388833.2933333TKX
09F10001104414.250994993.475555532.5841666FPP
09F10001104513.956002693.540833332.2211111B XNG
09F10001104614.667005493.659444428.1775000XNG
09F10001104714.666006293.659444428.1683333TKL
09F10001104814.302003493.998055527.8288888XNG
09F1000110495.8480075995.21500005.86944444XNG
09F1000110505.6329997194.29555554.58805556XNG
09F1000110515.6440075294.29583334.52611111B TKL
09F1000110525.9570018194.76027771.90194444ESL
09F1000110535.2630019195.7308333356.558055CP
09F1000110545.2449999294.5655555350.491666WL
09F1000110555.2180053994.424166615.5508333XNG
03NM0.00000000 09F1000110565.55000085109.601388349.831666B WL
09F1000110576.73799726105.351111341.740833WL
09F1000110585.42800047109.86388815.7680555FPP
09F1000110596.27600806103.933055289.974444WL
09F1000110607.19500754101.957222294.291666ELL
09F10001106110.089993198.0530555296.649444CL
09F1000110629.4989923697.5808333259.249722WL
09F1000110639.0190011798.1822222254.804722WL
09F1000110648.5929990398.9980555249.535833WL
09F10001106514.604006893.7686111249.677777ELL
09F10001106615.978001393.2552777259.905555CL
03NM1.94500000 09F10001106743.225998792.164444421.6475000B ELR
09F10001106843.906992592.185277719.6688888B TKR
09F10001106943.726007292.304166619.9713888B ESR
09F10001107041.945994092.177500018.5208333B XNG
09F10001107142.360006192.035000017.0791666XNG
13TS19-May-15 12:01
09F10001107238.183000692.054166614.5211111XNG
09F10001107337.653999292.128055516.0850000XNG
09F10001107435.105996792.069444414.2933333TKR
09F10001107534.945994092.197777714.7491666ESR
09F10001107634.241003292.037222217.4558333ELR
09F10001107728.694999191.877500010.1497222B LBR
09F10001107828.192992391.83166667.15055556B XNG
09F10001107924.416992791.63805559.42305556ELR
09F10001108025.510000291.69694446.27277778LBR
09F10001108124.470998791.77222222.32444444ESR
09F10001108228.771003791.69777775.26416667XNG
09F10001108325.502006891.5175000359.709444XNG
09F10001108425.489999891.5141666359.698611B FPL
09F10001108524.570001291.62500001.47666667XNG
09F10001108624.556995091.62388881.48972222TKR
09F10001108720.960998591.32750000.35305556B WL
09F10001108821.986993991.5936111357.339166WLX
09F10001108919.192992391.15000000.33833333ELR
09F10001109014.539992290.1091666341.607777ELR
09F10001109115.880997190.0500000327.598333WLX
09F10001109214.405002689.6725000329.373333WL
09F10001109318.678995491.1005555346.305000ESR
09F10001109418.889007490.8638888345.476944TKR
09F10001109516.087994789.7063888323.971944TKR
09F10001109615.766007989.9180555324.066944ESR
09F10001109714.872004689.5741666324.222222LBR
09F10001109822.649003489.7705555341.873333TREE 2
09F10001109926.456993391.3744444357.667500B FPR
09F10001110030.258006190.2177777350.316388XNGX
09F10001110127.451997589.9772222351.126388SH
09F10001110220.974004688.7627777321.126944SH
09F10001110318.487002389.3377777319.695277B EM
09F10001110423.829006489.0938888316.936111EM
09F10001110523.452996789.0280555308.471111EM
09F10001110618.360006188.7191666308.784166EM
13TS19-May-15 12:11
09F10001110718.328998088.7258333308.784444FPR
09F10001110817.052007788.7947222308.009722FPL
09F10001110917.022997888.7927777308.024166B XNG
09F10001111015.983996388.8311111307.482222XNG
09F10001111116.145997489.7200000323.371388B XNG
09F10001111217.168995289.5861111322.547222XNG
09F10001111312.981998087.7800000297.573888ELR
09F10001111415.170993688.3916666299.350277LBR
09F10001111514.136005788.0825000298.333888B WL
09F10001111615.678995489.0286111302.538888CP
09F10001111715.838998188.6991666299.140000ESR
09F10001111816.123998788.4288888299.815277TKR
09F10001111923.022997887.6027777304.675000B LB
09F10001112020.711002787.6038888304.235277LB
09F10001112123.788006686.9247222281.477777LB
09F10001112222.445003387.4125000277.427777B XNG
09F10001112318.068993586.8086111266.668888ELR
09F10001112417.108994287.2100000275.740555WL
09F10001112519.469000387.2002777270.673888LBR
09F10001112619.154007787.6294444275.948333ESR
09F10001112719.506003587.5497222276.732777TKR
09F10001112824.701993386.8077777280.564166B XNG
09F10001112926.579992986.8750000282.688333XNG
09F10001113025.624007287.0825000285.250000TD
09F10001113115.385002393.6944444236.986388B WLA
03NM0.00000000 09F10001113215.911006193.2230555243.305833WLA
09F10001113322.706006991.3561111236.994444WLA
09F10001113424.674998790.9438888245.691388CL
09F10001113534.188995689.8719444239.320555CL
09F10001113624.222002191.0483333238.725555ELL
13TS19-May-15 12:21
03NM1.94500000 09F10001113725.449999287.0138888286.797500WM
09F10001113820.598994187.5100000277.375277B XNG
09F10001113919.579992987.5602777276.574444XNG
09F10001114022.915002887.2108333266.209444B XNG
09F10001114123.454995087.2716666268.726111XNG
09F10001114227.063997786.7413888277.058611B LB
09F10001114325.879998086.8016666275.316666LB
09F10001114433.776998886.4183333259.748888LB
09F10001114534.970008086.4066666261.641666SH
03NM0.30000000 09F10001114636.877000588.7647222258.356111TREE 3
03NM1.94500000 09F10001114723.489999887.2663888268.828333FPL
09F10001114827.300005186.9388888279.148055B XNG
09F10001114925.545005086.8744444276.843888XNG
09F10001115023.583007387.3241666273.765000XNG
09F10001115124.425003087.2347222270.843055FPR
09F10001115223.593998286.9186111258.724722B WL
09F10001115332.488001586.9136111248.177222WL
09F10001115436.486003187.1222222247.925000ESR
09F10001115534.976003087.0169444249.713333TKR
09F10001115634.963996087.0152777249.720833B XNG
09F10001115735.871005486.9975000250.955555XNG
09F10001115839.228996386.9983333248.583333FPL
09F10001115939.235008286.9997222248.580000B XNG
09F10001116038.905993387.0225000247.011666XNG
09F10001116135.335992186.8047222243.679444ELR
09F10001116239.818997886.9783333250.177500FPR
09F10001116339.799996686.9758333250.185555B XNG 13OS41.800 86-31'34" 252-14'01" OS 1.500 13OSDirn
09F10001124622.340697786.9168858206.216384TREE 2 13OS28.368 86-41'30" 215-45'33" OS 2.000 13OSDirn >
09F10001124728.438414086.6998673211.719664TREE 2
09F10001124827.211993486.8908333211.730000B BEL
09F10001124927.841995687.0955555215.432777BEL
09F10001125033.776998886.8905555218.392777BEL
09F10001125144.974004687.6080555227.251944B FBB
09F10001125244.885993087.3291666224.261666FPB
09F10001125346.802994187.3825000224.171666FPB
09F10001125446.921997087.5055555225.710000SIGN BUS
09F10001125546.847008487.6177777227.087222FPB
09F10001125645.033006587.6141666228.985000LBL
09F10001125747.271994487.6327777228.671666LBL
09F10001125844.774001387.7283333227.816111ESL
09F10001125944.759995987.6144444227.461388TKL
09F10001126052.424003887.3905555221.979166PP
09F10001126148.930007387.3572222222.500555FPA
09F10001126248.889007487.4150000224.034444FPP
03NM1.94500000 09F10001126346.709004487.0075000238.657222ELR
09F10001126447.488001587.2133333241.981388ESR
09F10001126547.480008187.1300000242.416388TKR
09F10001126646.853003487.0305555239.091111YLX
09F10001126751.795999987.1441666237.532500YLX
09F10001126852.463005387.3013888240.022500YLX
09F10001126951.754000987.1311111237.148888ELR
13TS19-May-15 11:14
13JS10000
13TS19-May-15 11:15
13TS19-May-15 11:40
13TS19-May-15 11:51
13TS19-May-15 12:01
13TS19-May-15 12:11
13TS19-May-15 12:21
