I downloaded a kmz field and converted it to a GDB fc on arcmap.
However, the field I need to label the layer by is stored in the pop-up html field...
It looks like this:
Benchmark: 100 Point ID 100 Type Vertical Northing 2119938 Easting 533366 Elevation (NAVD88) 6.1 ft Elevation (NGVD29) 7.18 ft All I need is the benchmark number (Benchmark: 100) from each field
Is there a way to either extract fields from the popup field OR create a new field based on the sorted popup field?
Tried a bit of the code here: How to populate Unique ID field after sorting?
but did not get anywhere.
Any advice would be greatly appreciated
It looks like this:
