How to create mask bands in GDAL and Python?
I have small program in Python that uses gdal and numpy to perform a logarithmic scale of some data into the RGB 0-255 range.
Now this input data has a nodata value set to mask the valid values, and I would like to have the output to retain that mask.
Obviously I can't use nodata for my output as I am ussing the full byte range for colour values.
From what I can tell from the GDAL API I need to create a mask band in the output file.
I added the code to do this but suddenly the program started running really slow and the output file size became huge.
What it the best way to do this?
Here is my code:
#!/usr/bin/env pythonimport gdalfrom gdalconst import *import numpyimport sysinfile = sys.argv[1]outfile = sys.argv[2]format = 'GTiff'type = GDT_Byteindataset = gdal.Open(infile, GA_ReadOnly)gdal.SetConfigOption('GDAL_TIFF_INTERNAL_MASK', 'YES')out_driver = gdal.GetDriverByName(format)outdataset = out_driver.Create(outfile, indataset.RasterXSize, indataset.RasterYSize, indataset.RasterCount, type)outdataset.CreateMaskBand(gdal.GMF_PER_DATASET)gt = indataset.GetGeoTransform()outdataset.SetGeoTransform(gt)prj = indataset.GetProjectionRef()outdataset.SetProjection(prj)for iBand in range(1, indataset.RasterCount + 1): inband = indataset.GetRasterBand(iBand) inmaskband = inband.GetMaskBand() outband = outdataset.GetRasterBand(iBand) outmaskband = outband.GetMaskBand() for i in range(inband.YSize - 1, -1, -1): scanline = inband.ReadAsArray(0, i, inband.XSize, 1, inband.XSize, 1) scanline = numpy.multiply(numpy.divide(numpy.log1p(numpy.minimum(10000, numpy.maximum(0, scanline))), numpy.log1p(10000)), 255) outband.WriteArray(scanline, 0, i) scanline = inmaskband.ReadAsArray(0, i, inband.XSize, 1, inband.XSize, 1) outmaskband.WriteArray(scanline, 0, i)
