If i have picture with this metadata in exif header:
Size is 4000, 3000Coordinate System is `'Metadata: EXIF_ApertureValue=(3.625) EXIF_ColorSpace=1 EXIF_ComponentsConfiguration=0x1 0x2 0x3 00 EXIF_CompressedBitsPerPixel=(5) EXIF_CustomRendered=0 EXIF_DateTime=2015:09:09 15:27:28 EXIF_DateTimeDigitized=2015:09:09 15:27:28 EXIF_DateTimeOriginal=2015:09:09 15:27:28 EXIF_DigitalZoomRatio=(1) EXIF_ExifVersion=0230 EXIF_ExposureBiasValue=(0) EXIF_ExposureMode=0 EXIF_ExposureTime=(0.0005) EXIF_FileSource=0x3 EXIF_Flash=16 EXIF_FlashpixVersion=0100 EXIF_FNumber=(3.5) EXIF_FocalLength=(4.5) EXIF_FocalPlaneResolutionUnit=2 EXIF_FocalPlaneXResolution=(16393.4) EXIF_FocalPlaneYResolution=(16393.4) EXIF_GPSAltitude=(91.8) EXIF_GPSAltitudeRef=00 EXIF_GPSDateStamp=2015:09:09 EXIF_GPSLatitude=(45) (18) (3.564) EXIF_GPSLatitudeRef=N EXIF_GPSLongitude=(19) (48) (19.842) EXIF_GPSLongitudeRef=E EXIF_GPSMapDatum=WGS-84 EXIF_GPSStatus=A EXIF_GPSTimeStamp=(14) (27) (29) EXIF_GPSVersionID=0x2 0x3 00 00 EXIF_ImageDescription= EXIF_Interoperability_Index=R98 EXIF_Interoperability_Version=0x30 0x31 0x30 0x30 EXIF_ISOSpeedRatings=800 EXIF_Make=Canon EXIF_MakerNote= EXIF_MaxApertureValue=(3.625) EXIF_MeteringMode=5 EXIF_Model=Canon PowerShot SX280 HS EXIF_Orientation=1 EXIF_PixelXDimension=4000 EXIF_PixelYDimension=3000 EXIF_Related_Image_Length=3000 EXIF_Related_Image_Width=4000 EXIF_ResolutionUnit=2 EXIF_SceneCaptureType=0 EXIF_SensingMethod=2 EXIF_ShutterSpeedValue=(10.9688) EXIF_UserComment= EXIF_WhiteBalance=1 EXIF_XResolution=(180) EXIF_YCbCrPositioning=2 EXIF_YResolution=(180)Image Structure Metadata: COMPRESSION=JPEG INTERLEAVE=PIXEL SOURCE_COLOR_SPACE=YCbCrCorner Coordinates:Upper Left ( 0.0, 0.0)Lower Left ( 0.0, 3000.0)Upper Right ( 4000.0, 0.0)Lower Right ( 4000.0, 3000.0)Center ( 2000.0, 1500.0)Band 1 Block=4000x1 Type=Byte, ColorInterp=Red Overviews: 2000x1500, 1000x750, 500x375 Image Structure Metadata: COMPRESSION=JPEGBand 2 Block=4000x1 Type=Byte, ColorInterp=Green Overviews: 2000x1500, 1000x750, 500x375 Image Structure Metadata: COMPRESSION=JPEGBand 3 Block=4000x1 Type=Byte, ColorInterp=Blue Overviews: 2000x1500, 1000x750, 500x375 Image Structure Metadata: COMPRESSION=JPEGHow should i format appropriate .jgw file for this picture?
