Good day to everyone,
I'm using a WFS SelectFeature from OpenLayers 2 to show a Popup containing the features' attributes from line layers and point layers (from GeoServer). This works fine, but I would like to create a buffer (similar to the clickTolerance in the WFS GetFeature) around the point/line, so that I wouldn't have to click exactly on the center of the feature to select it. As i've searched through the Q&A, I found related questions, but no answer worked for me so far.
My code is here:
var map; // pink tile avoidance OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5; // make OL compute scale according to WMS spec OpenLayers.DOTS_PER_INCH = 25.4 / 0.28; function init(){ // Save-strategy var saveStrategy = new OpenLayers.Strategy.Save(); // Controls var controls = [ new OpenLayers.Control.ArgParser(), new OpenLayers.Control.Attribution(), new OpenLayers.Control.Navigation(), new OpenLayers.Control.PanZoomBar({position: new OpenLayers.Pixel(2, 15)}), new OpenLayers.Control.LayerSwitcher(), new OpenLayers.Control.ScaleLine(), new OpenLayers.Control.Scale(document.getElementById('scale')), new OpenLayers.Control.MousePosition({element: document.getElementById('location')}) ]; ///// var options = { scales: [500000, 100000, 50000, 25000, 10000, 5000], projection: "EPSG:4326", displayProjection: "EPSG:4326", units: 'm' } ///// map = new OpenLayers.Map('map', /*{controls: controls}*/ options); //Basemaps var osm = new OpenLayers.Layer.OSM("Simple OSM Map"); var gsat = new OpenLayers.Layer.Google("Google Satellite", {type: google.maps.MapTypeId.SATELLITE, numZoomLevels: 22} ); var gter = new OpenLayers.Layer.Google("Google Terrain", {type: google.maps.MapTypeId.TERRAIN, numZoomLevels: 22} ); //Add Basemaps map.addLayers([gter, osm, gsat]); //Layer var test = new OpenLayers.Layer.Vector("xName", { strategies: [new OpenLayers.Strategy.Fixed(), saveStrategy], protocol: new OpenLayers.Protocol.WFS({ url: SETTINGS.BASE_URL, featurePrefix: 'xNS', featureNS: "xNS", //extractAttributes: true, featureType: "xName", }), styleMap: new OpenLayers.StyleMap({ "default": new OpenLayers.Style({ "pointRadius": 2, fill: true, fillColor: "#8d006a", strokeColor: "#000000", strokeWidth: 0.2 }) }) }); //Add Layer map.addLayer(test); //add Popup var select = new OpenLayers.Control.SelectFeature(test, { hover: false, toggle: true, box: false, }); map.addControl(select); select.activate(); function onPopupClose(evt) { selectControl.unselect(selectedFeature); } test.events.on({ featureselected: function(event) { var feature = event.feature; console.log(feature); feature.popup = new OpenLayers.Popup.FramedCloud ("pop", feature.geometry.getBounds().getCenterLonLat(), null, feature.attributes["xx"] + " " + feature.attributes["xx"], null, true //Boolean indicating if the close buttons must be shown ); map.addPopup(feature.popup); }, // destroy popup when feature is no longer selected. Prevents showing 2 Popups at the same time featureunselected: function(event) { var feature = event.feature; map.removePopup(feature.popup); feature.popup.destroy(); feature.popup = null; } }); //Set Map Center map.setCenter( new OpenLayers.LonLat(27.1, 47.55).transform( new OpenLayers.Projection("EPSG:4326"), map.getProjectionObject() ), 9 ); }
I have also tried WFS GetFeature with clickTolerance, but it doesn't seem to work, nothing is selected on the map.
Code:
var select = new OpenLayers.Layer.Vector("Selection", {styleMap: new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"])}); map.addLayer(select); getfeature = new OpenLayers.Control.GetFeature({ protocol: new OpenLayers.Protocol.WFS({ url: SETTINGS.BASE_URL, featurePrefix: 'xNS', featureNS: "xNS", //extractAttributes: true, featureType: "xName" }), box: true, hover: true, multipleKey: "shiftKey", toggleKey: "ctrlKey", clickTolerance: 1000 }); getfeature.events.register("featureselected", this, function { select.addFeatures([feature]); }); getfeature.events.register("featureunselected", this, function { select.removeFeatures([feature]); }); map.addControl(getfeature); getfeature.activate();Cloning the features with bigger invisible ones wouldn't help, due to the large number of features and layers I already have.
Any help is appreciated. Best regards, Raluca
My code is here:
Code:
