How to correctly use arcpy.da.Editor
I am attempting to remove duplicates in a feature class that are generated by a Python script. At the end of my script I have the code block below; I haven't implemented it yet, but would like to see if this is the correct way to use arcpy.da.Editor as the errors that I have been receiving are in regards to being outside of an edit session. Is arcpy.da.Editor being used correctly here?
fields = ['OBJECTID', 'SRNumber', 'ItemLoc_9'] table_rows = [] delete_rows = [] where_clause = """ ItemLoc_9 = ' '""" with arcpy.da.Editor(appendClass) as edit: with arcpy.da.SearchCursor(appendClass, fields, where_clause) as cursor: for row in cursor: if [row[1], row[2]] in table_rows: delete_rows.append(row[0]) else: table_rows.append([row[1], row[2]]) del table_rows with arcpy.da.UpdateCursor(appendClass, ['OBJECTID']) as cursor2: for row in cursor2: if row[0] in delete_rows: print 'Deleting record: OBJECTID = ' + str(row[0]) cursor2.deleteRow() print '\ndone'`
