I have successfully installed OSGeo4W64 on numerous new systems (actually EC2 instances) and had no issues. But I've run into an issue with it on a Windows 7 workstation that has a lot of JREs on it. Because of that, I set my paths from a batch to whatever JRE I need to use. But I can't get any of 64-bit versions to work:a ogrinfo --help throws the missing jvm.dll machine error message.
Which JRE should I be using and how should the pathing for the JAVA_HOME and PATH variables be set?
Update:
Update:
- Removed all JREs/SDKs.
- Installed JRE 1.7 (jre1.7.0_67) - 64 bit.
- Set the JAVA_HOME and PATH variables.
- Started ogrinfo.exe and received a different error:
