How to convert File Geodatabase to Personal Geodatabase [duplicate]
This question already has an answer here:
I have a file geodatabase (gdb) and I want to convert it to personal geodatabase. I am using ArcMap 10.2. Does esri support this conversion? Any easy steps?
what I would like to achieve is to access the database file (as .dbf in a raw shapefile) inside my geodatabase. I want to do some python scripting to changepath name for a map package. Its quite complicated to explain but this is for the map package I am creating. In the map package I have hyperlink of PDF, photo and Autocad Files. If somebody uses my map package the path obviously change and the map package does not support this hyperlink of files.
