How to convert a NetCDF file to GeoTIFF using GDAL
I have a NetCDF file which contains data for the number of rain days in the UK. I'd like to convert it to a GeoTIFF, but can't get GDAL correctly georeference it. See dumps from gdalinfo below.
I want a single band TIFF showing the "raindays_tmean_abs" variable. The "lat" and "lon" variables seem to have sensible min/max values to put the data over the UK, but when I convert it with gdal_translate it ends up off the west coast of Africa.
There is a warning about the first dimension not being a "Time or Vertical" dimension. I read that gdal expects the data to be in a certain order, so maybe this is the problem, but I don't know how to modify it.
How do I convert/reproject this data?
gdalinfo NETCDF:RainDays1_1961-1990_LTA_25km.nc
Warning 1: dimension #0 (meaning_period) is not a Time or Vertical dimension.Driver: netCDF/Network Common Data FormatFiles: RainDays1_1961-1990_LTA_25km.nc RainDays1_1961-1990_LTA_25km.nc.aux.xmlSize is 39, 52Coordinate System is `'Origin = (-17.650008352179277,11.329999312758446)Pixel Size = (0.219999614514803,-0.219999998807907)Metadata: axis_0#units= meaning_period#comment=Meaning periods are all months (12) beginning January, all seasons (4) beginning Winter (DJF) and Annual (1) meaning_period#long_name=meaning_period meaning_period#units= NC_GLOBAL#Conventions=CF-1.0 NETCDF_DIM_EXTRA={meaning_period} NETCDF_DIM_meaning_period_DEF={17,6} NETCDF_DIM_meaning_period_VALUES={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16} raindays_tmean_abs#comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. raindays_tmean_abs#coordinates=lon lat raindays_tmean_abs#long_name=Number of days per meaning period having a rainfall >= 1 mm (days) raindays_tmean_abs#missing_value=1e+020 raindays_tmean_abs#name=rain_days raindays_tmean_abs#title=rain_days raindays_tmean_abs#units=days rlat#axis=Y rlat#bounds=bounds_rlat rlat#long_name=latitude in rotated pole grid rlat#standard_name=grid_latitude rlat#units=degrees rlon#axis=X rlon#bounds=bounds_rlon rlon#long_name=longitude in rotated pole grid rlon#modulo=360 rlon#standard_name=grid_longitude rlon#topology=circular rlon#units=degreesSubdatasets: SUBDATASET_1_NAME=NETCDF:"RainDays1_1961-1990_LTA_25km.nc":bounds_rlat SUBDATASET_1_DESC=[52x2] bounds_rlat (64-bit floating-point) SUBDATASET_2_NAME=NETCDF:"RainDays1_1961-1990_LTA_25km.nc":bounds_rlon SUBDATASET_2_DESC=[39x2] bounds_rlon (64-bit floating-point) SUBDATASET_3_NAME=NETCDF:"RainDays1_1961-1990_LTA_25km.nc":lat SUBDATASET_3_DESC=[52x39] latitude (32-bit floating-point) SUBDATASET_4_NAME=NETCDF:"RainDays1_1961-1990_LTA_25km.nc":lon SUBDATASET_4_DESC=[52x39] longitude (32-bit floating-point) SUBDATASET_5_NAME=NETCDF:"RainDays1_1961-1990_LTA_25km.nc":raindays_tmean_abs SUBDATASET_5_DESC=[17x52x39] raindays_tmean_abs (32-bit floating-point)Geolocation: LINE_OFFSET=0 LINE_STEP=1 PIXEL_OFFSET=0 PIXEL_STEP=1 SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]] X_BAND=1 X_DATASET=NETCDF:"RainDays1_1961-1990_LTA_25km.nc":lon Y_BAND=1 Y_DATASET=NETCDF:"RainDays1_1961-1990_LTA_25km.nc":latCorner Coordinates:Upper Left ( -17.6500084, 11.3299993) Lower Left ( -17.6500084, -0.1100006) Upper Right ( -9.0700234, 11.3299993) Lower Right ( -9.0700234, -0.1100006) Center ( -13.3600159, 5.6099993) Band 1 Block=39x1 Type=Float32, ColorInterp=Undefined Min=10.658 Max=22.949 Minimum=10.658, Maximum=22.949, Mean=15.625, StdDev=3.151 NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=0 NETCDF_VARNAME=raindays_tmean_abs STATISTICS_MAXIMUM=22.949373245239 STATISTICS_MEAN=15.624619410087 STATISTICS_MINIMUM=10.657625198364 STATISTICS_STDDEV=3.1508820627895 title=rain_days units=daysBand 2 Block=39x1 Type=Float32, ColorInterp=Undefined Min=7.893 Max=17.172 Minimum=7.893, Maximum=17.172, Mean=11.591, StdDev=2.282 NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=1 NETCDF_VARNAME=raindays_tmean_abs STATISTICS_MAXIMUM=17.172254562378 STATISTICS_MEAN=11.591275386767 STATISTICS_MINIMUM=7.8926663398743 STATISTICS_STDDEV=2.28225356537 title=rain_days units=daysBand 3 Block=39x1 Type=Float32, ColorInterp=Undefined Min=9.700 Max=21.762 Minimum=9.700, Maximum=21.762, Mean=13.882, StdDev=2.988 NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=2 NETCDF_VARNAME=raindays_tmean_abs STATISTICS_MAXIMUM=21.761842727661 STATISTICS_MEAN=13.88236379732 STATISTICS_MINIMUM=9.7001943588257 STATISTICS_STDDEV=2.9875935432638 title=rain_days units=daysBand 4 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=3 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 5 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=4 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 6 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=5 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 7 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=6 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 8 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=7 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 9 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=8 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 10 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=9 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 11 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=10 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 12 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=11 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 13 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=12 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 14 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=13 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 15 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=14 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 16 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=15 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysBand 17 Block=39x1 Type=Float32, ColorInterp=Undefined NoData Value=1.0000000200408773e+020 Metadata: comment=Converted from UKCP09 monthly data to climatologies and then averaged to 25km rotated pole grid. coordinates=lon lat long_name=Number of days per meaning period having a rainfall >= 1 mm (days) missing_value=1e+020 name=rain_days NETCDF_DIM_meaning_period=16 NETCDF_VARNAME=raindays_tmean_abs title=rain_days units=daysgdalinfo NETCDF:RainDays1_1961-1990_LTA_25km.nc:lon
Driver: netCDF/Network Common Data FormatFiles: RainDays1_1961-1990_LTA_25km.nc RainDays1_1961-1990_LTA_25km.nc.aux.xmlSize is 39, 52Coordinate System is `'Origin = (-17.650008352179277,11.329999312758446)Pixel Size = (0.219999614514803,-0.219999998807907)Metadata: axis_0#units= lon#long_name=longitude lon#missing_value=1e+020 lon#name=lon lon#standard_name=longitude lon#units=degrees_east meaning_period#comment=Meaning periods are all months (12) beginning January, all seasons (4) beginning Winter (DJF) and Annual (1) meaning_period#long_name=meaning_period meaning_period#units= NC_GLOBAL#Conventions=CF-1.0 rlat#axis=Y rlat#bounds=bounds_rlat rlat#long_name=latitude in rotated pole grid rlat#standard_name=grid_latitude rlat#units=degrees rlon#axis=X rlon#bounds=bounds_rlon rlon#long_name=longitude in rotated pole grid rlon#modulo=360 rlon#standard_name=grid_longitude rlon#topology=circular rlon#units=degreesCorner Coordinates:Upper Left ( -17.6500084, 11.3299993) Lower Left ( -17.6500084, -0.1100006) Upper Right ( -9.0700234, 11.3299993) Lower Right ( -9.0700234, -0.1100006) Center ( -13.3600159, 5.6099993) Band 1 Block=39x1 Type=Float32, ColorInterp=Undefined Min=-15.830 Max=3.672 Minimum=-15.830, Maximum=3.672, Mean=-5.246, StdDev=4.393 NoData Value=1.0000000200408773e+020 Metadata: long_name=longitude missing_value=1e+020 name=lon NETCDF_VARNAME=lon standard_name=longitude STATISTICS_MAXIMUM=3.671746969223 STATISTICS_MEAN=-5.2457962955782 STATISTICS_MINIMUM=-15.830010414124 STATISTICS_STDDEV=4.3927366732513 units=degrees_eastgdalinfo NETCDF:RainDays1_1961-1990_LTA_25km.nc:lat
Driver: netCDF/Network Common Data FormatFiles: RainDays1_1961-1990_LTA_25km.nc RainDays1_1961-1990_LTA_25km.nc.aux.xmlSize is 39, 52Coordinate System is `'Origin = (-17.650008352179277,11.329999312758446)Pixel Size = (0.219999614514803,-0.219999998807907)Metadata: axis_0#units= lat#long_name=latitude lat#missing_value=1e+020 lat#name=lat lat#standard_name=latitude lat#units=degrees_north meaning_period#comment=Meaning periods are all months (12) beginning January, all seasons (4) beginning Winter (DJF) and Annual (1) meaning_period#long_name=meaning_period meaning_period#units= NC_GLOBAL#Conventions=CF-1.0 rlat#axis=Y rlat#bounds=bounds_rlat rlat#long_name=latitude in rotated pole grid rlat#standard_name=grid_latitude rlat#units=degrees rlon#axis=X rlon#bounds=bounds_rlon rlon#long_name=longitude in rotated pole grid rlon#modulo=360 rlon#standard_name=grid_longitude rlon#topology=circular rlon#units=degreesCorner Coordinates:Upper Left ( -17.6500084, 11.3299993) Lower Left ( -17.6500084, -0.1100006) Upper Right ( -9.0700234, 11.3299993) Lower Right ( -9.0700234, -0.1100006) Center ( -13.3600159, 5.6099993) Band 1 Block=39x1 Type=Float32, ColorInterp=Undefined Min=47.594 Max=60.806 Minimum=47.594, Maximum=60.806, Mean=54.186, StdDev=3.229 NoData Value=1.0000000200408773e+020 Metadata: long_name=latitude missing_value=1e+020 name=lat NETCDF_VARNAME=lat standard_name=latitude STATISTICS_MAXIMUM=60.805950164795 STATISTICS_MEAN=54.185836173138 STATISTICS_MINIMUM=47.594329833984 STATISTICS_STDDEV=3.228754901642 units=degrees_north
