How to configure QGIS and SAGA on Ubuntu (12.04 and others)?
During the past weeks, I have tried QGIS to recognize SAGA via the processing toolbox, both being installed from the ubuntugis-unstable repository. I have tried this on several virtual ubuntu operating systems which I specifically set up for using QGIS. However, I always get the same "Missing dependency.This algorithm cannot be run" (sic) error message. Here's some more information:
  • I have tried (l)ubuntu 12.04, 13.04 and 13.10 (each 64bit), installing packages from the respective repos. I
  • I am now an ubuntu 12.04 32bit VM
  • I am well aware of this post, and yes, this workaround would do the trick! However, installing from the qgis repositories is not an option for me, as I also need the orfeo toolbox packages, which are not provided there :(
  • Package versions are qgis 2.2.0-1, saga 2.1.1 and python-saga 2.1.1. I had the same problem with the preceding QGIS version.
  • I checked the PATH variable and successfully launched saga_cmd, so everything seems to be in its place.
Any help is appreciated -- including first guesses on what may be the problem :)
