How to compare two sets of points in QGIS?
I have two point layers with XYZ data; one set are points measured in the field and the second set is a Lidar data set.
I want to check the accuracy of the Lidar in comparison to the measured data.
Is there a way to do so without creating grids? That is, comparing the vectors and not the rasters?
Note: I found similar questions but either there was no answer or it referred to ArcGIS for Desktop.
