How to compact sld files?
I have 3 SLD file (let's cal them 2013, 2014, 2015) which are related to three shp file. The shapefiles are identical except from the fact that one has data quantity from 2013 and so on. Therefore instead of using 3 separate SLD files I would like to compact them in order to use the same sld for each of the 3 shapefiles.
At the moment this is the kind of SLD I'm using:
L005 Regioni 2013 PMerc group 0 Feature 0 ton Ton2013 0 #2C7BB6 Da 0 ton a 50 ton Ton2013 0 Ton2013 50 #6DA9CD Da 50 ton a 200 ton Ton2013 50 Ton2013 200 #A7D3E0 Da 200 ton a 400 ton Ton2013 200 Ton2013 400 #DEEFCB Da 400 ton a 600 ton Ton2013 400 Ton2013 600 #FFF7AF Da 600 ton a 800 ton Ton2013 600 Ton2013 800 #FCCA75 Da 800 ton a 1000 ton Ton2013 800 Ton2013 1000 #F7904B >1000 ton Ton2013 1000 Ton2013 5000 #EA3D2D where I always need to change Ton2013 in Ton2014, Ton2015 and so on.
Basically I would like to insert in my sld file something like
"if you don't find Ton2013 then use Ton2014, if you don't this either use Ton2015 and so on"
Colours and ranges of greater and smaller remain the same through the years.
