In Python 2.7, I try to do a WFS request from behind an authenticated proxy server (proxy requiring username/password). I managed to communicate to a webserver via the authenticated proxy using a ProxyHandler. I also managed to communicate with a WFS server in a network without the proxy. Now I'd like to combine the two. This is my code for testing:
from owslib.wfs import WebFeatureServiceimport urllib2proxy_url = 'username
assword@server
ort' # replace with real settings!proxy = urllib2.ProxyHandler({'https': proxy_url})opener = urllib2.build_opener(proxy, urllib2.HTTPHandler)urllib2.install_opener(opener)wfs_url = 'https://viewer.image-v.be/MM_Opnameposities?service=WFS&request=GetCapabilities'response = urllib2.urlopen(wfs_url, timeout=1)print response.read()# is okwfs_url = 'https://viewer.image-v.be/MM_Opnameposities'wfs = WebFeatureService(wfs_url)# error: Failed to establish a new connection: [Errno 10060]gml = wfs.getfeature( typename='orbit:MM_AGIV_MR__1', bbox=(207943,166669,208043,166769), srsname='urn:x-ogc:def:crs:EPSG:31370' )print gml.read()# is not okAlso note that the WFS server uses HTTPS: this could make things more complicated.
Why do I get an error trying to instantiate a WebFeatureService object?Does the WebFeatureService object actually use the installed opener? If not, how can I make sure the WebFeatureService (or any Web-x-Service communication in library owslib) is taking the proxy settings into account? I've looked into the code of WebFeatureService and urllib2.urlopen is used there as well.
Thanks.
Thanks.
