Is there any way to clear a JMapFrame and all of its layers before opening a new file? I currently am running into an error (exception no stack trace) while opening a file with one already open that has multiple layers added to it (with the layers pane).
fileMenu.add(new SafeAction("Open File...") { @Override public void action(ActionEvent e) throws Throwable { setJFCFilter("Shapefiles", "shp"); int returnVal = jfc.showOpenDialog(jframe); if (returnVal == JFileChooser.APPROVE_OPTION) { String pathname = jfc.getSelectedFile().getAbsolutePath(); URL shape = acquireURL(pathname); if (shape == null) { JOptionPane.showMessageDialog(jframe, "could not find file \"" + pathname + "\"", "Could not find file", JOptionPane.ERROR_MESSAGE); } try { if (layers_size > 1) { for (int i = 0; i < layerList.size(); i++) { //jframe.getMapContent().layers().get(i).dispose(); map.removeLayer(layerList.get(i)); } shapeFile = new File(pathname); loadFile(shape); //worldAf = jframe.getMapPane().getScreenToWorldTransform(); //scaleRatio = new BigDecimal(worldAf.getScaleX()); } else { shapeFile = new File(pathname); loadFile(shape); worldAf = jframe.getMapPane().getScreenToWorldTransform(); scaleRatio = new BigDecimal(worldAf.getScaleX()); } } catch (Exception ex) { Logger.getLogger(ShapefileExporter.class.getName()).log(Level.SEVERE, null, ex); } } } // End Action }); // End ListenerLoad File
// Load shapefile into JMapFrame protected void loadFile(URL shape) throws IOException { try { FileDataStore store = FileDataStoreFinder.getDataStore(shape); featureSource = store.getFeatureSource(); ShapefileDataStore ds = new ShapefileDataStore(shape); FeatureSource fs = ds.getFeatureSource(); collection = fs.getFeatures(); FeatureArray = features(); map = new MapContent(); Style style = SLD.createSimpleStyle(featureSource.getSchema()); Layer layer = new FeatureLayer(featureSource, style); map.addLayer(layer);layerList = new ArrayList(); layerList.add(layer); jframe.setMapContent(map); } catch (IOException ex) { Logger.getLogger(ShapefileExporter.class.getName()).log(Level.SEVERE, null, ex); } }After running this bit of code, I run some more to add a layer. Once this second layer has been added if I run this code again (opening a different file) the exception happens.
Also I don't think I can post the full code as its over 1000 lines of code.
Exception
SEVERE: nulljava.lang.NullPointerException at com.mycompany.shapefileexporter.mvn.ShapefileExporter$1.action(ShapefileExporter.java:183) at org.geotools.swing.action.SafeAction.actionPerformed(SafeAction.java:50) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.AbstractButton.doClick(AbstractButton.java:376) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833) at com.apple.laf.AquaMenuItemUI.doClick(AquaMenuItemUI.java:157) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3321) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)Update: Followed @iant advice and still running into null pointer exceptions, and the layers, after removing are still there (I managed to delete one but received multiple null pointer exceptions).
Exception
