I'm new in using ModelBuilder or Python script. So, i have a set of contour data and a good contour data should contain a spotheight* in every closed polyline contour data.
Is there any solution to check that every closed polyline of contour data should contain spotheight which also have same elevation or above.
*) spotheight is a point that located in closed polyline contour data which show the elevation value
