Is there a way to save the output JPG, changing the output file name to the page name, instead of page number?
I mean changing the script found in this post?
import_path = r"..." # Path of .mxd export_path = r"..." # Path of output file field_name = "Name" # Name of field used to sort DDP mxd = arcpy.mapping.MapDocument(import_path) for i in range(1, mxd.dataDrivenPages.pageCount + 1): mxd.dataDrivenPages.currentPageID = i row = mxd.dataDrivenPages.pageRow print row.getValue(field_name) arcpy.mapping.ExportToJPEG(mxd, export_path + "." + row.getValue(field_name) + ".jpg") del mxd
