How to change field name in raster file?
I´m having a bit of an understanding problem with a DEM TIF file. I have a DEM TIF file which is served with Geoserver. When I click on the layer the WMSGetFeatureInfo gives me the following output:
GREY_INDEX110.0
I realise that the 110.0 is the height, but what I don´t understand is why the raster field is called grey_index. The DGM was produced from a point shapefile which was then interpolated using spatialanalyst. The height field in the shapefile was called "z" so why is this then converted to "grey_index"?
For the WMSGetFeatureInfo I would like to change the field name to "Height" but how do I do this? Is this really a "Field" in the same sense as a shapefile dbf? Am I able to just change field names in raster files?
I have GDAL and ESRI libraries available if anyone can help.
Cheers,Rob
