I am trying to calculate the areas of some polygons and i want to use the field calculator to measure the area. The result i got using this method is different from using the QGIS measurement tool. I am confused on which is correct. How can i do this correctly?Also is it possible to change the measurement unit of the field calculator to give result in meter square?
