I have two tables of roads - the same roads, from different sources, and am trying to compare how similar their positions are. I'm wanting to buffer each road in one of the feature classes and calculate the % overlap between it and the corresponding road from the other feature class. Could obviously do this manually but since there are hundreds of roads would rather use Python. The thing is, I'm new to it. Any help on how to automate using the intersect tool between objects from different tables would be very welcome. The objects will have an attribute in common.
