the problem is when i use the layout of one part from the fishnet i got 24 empty PDFs and only one with the layout i already start with , But when i use the layout of the whole map it kind of works , and i got 25 PDFs with the 25 parts of the Fishnet but it look like this
gp=arcgisscripting.create() arcpy.env.overwriteOutput=True mxd=arcpy.mapping.MapDocument(r"D:\PFE\data\carte.mxd") df=arcpy.mapping.ListDataFrames(mxd, "*")[0] print df
source_geod= arcpy.mapping.Layer(r"D:\PFE\data\PFE\traitement\geod.lyr") source_RR= arcpy.mapping.Layer(r"D:\PFE\data\PFE\traitement\RR.lyr") source_oueds= arcpy.mapping.Layer(r"D:\PFE\data\PFE\traitement\oueds.lyr") source_SBKA= arcpy.mapping.Layer(r"D:\PFE\data\PFE\traitement\SBKA.lyr") source_Veg= arcpy.mapping.Layer(r"D:\PFE\data\PFE\traitement\Veg.lyr")
i=0 fc=(r"D:\PFE\data\fishnet1.shp") rows=arcpy.SearchCursor(fc)
for row in rows: print i print row
layerFishnet_src=gp.MakeFeatureLayer_management(fc, "lyr") layerFishnet=gp.SelectLayerByAttribute_management("lyr", "NEW_SELECTION",'("FID" = ' + str(i) + ')' ) geod_i= arcpy.Clip_analysis(r"D:\PFE\data\Geod.shp", layerFishnet, r"D:\PFE\data\Geod_"+str(row.getValue("FID"))+".shp") rr_i= arcpy.Clip_analysis(r"D:\PFE\data\RR.shp", layerFishnet, r"D:\PFE\data\RR_"+str(row.getValue("FID"))+".shp") oueds_i= arcpy.Clip_analysis(r"D:\PFE\data\oueds.shp", layerFishnet, r"D:\PFE\data\oueds_"+str(row.getValue("FID"))+".shp") SBKA_i= arcpy.Clip_analysis(r"D:\PFE\data\SBKA.shp", layerFishnet, r"D:\PFE\data\SBKA_"+str(row.getValue("FID"))+".shp") Veg_i= arcpy.Clip_analysis(r"D:\PFE\data\Veg.shp", layerFishnet, r"D:\PFE\data\Veg_"+str(row.getValue("FID"))+".shp") geoidlyr=gp.MakeFeatureLayer_management(geod_i, "geoidlyr") rrlyr=gp.MakeFeatureLayer_management(rr_i, "rrlyr") ouedslyr=gp.MakeFeatureLayer_management(oueds_i, "ouedslyr") SBKAlyr=gp.MakeFeatureLayer_management(SBKA_i, "SBKAlyr") Veglyr=gp.MakeFeatureLayer_management(Veg_i, "Veglyr") geoid=arcpy.mapping.Layer(geoidlyr) rr=arcpy.mapping.Layer(rrlyr) oueds=arcpy.mapping.Layer(ouedslyr) SBKA=arcpy.mapping.Layer(SBKAlyr) Veg=arcpy.mapping.Layer(Veglyr) lyrr = arcpy.mapping.ListLayers(mxd)[3] print lyrr lygeoid = arcpy.mapping.ListLayers(mxd)[2] print lygeoid lyoueds = arcpy.mapping.ListLayers(mxd)[4] print lyoueds lySBKA = arcpy.mapping.ListLayers(mxd)[6] print lySBKA lyVeg = arcpy.mapping.ListLayers(mxd)[5] print lyVeg arcpy.mapping.UpdateLayer( df, lygeoid ,geoid, false ) arcpy.mapping.UpdateLayer( df, lyrr ,rr, False) arcpy.mapping.UpdateLayer( df, lyoueds ,oueds, False) arcpy.mapping.UpdateLayer( df, lySBKA ,SBKA, False) arcpy.mapping.UpdateLayer( df, lyVeg ,Veg, False) titleTxt= arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "title") titleTxt=row.getValue("name") print titleTxt arcpy.mapping.ExportToPDF(mxd,r"D:\PFE" + row.getValue("name") + ".pdf") i = i + 1
