i'm on windows 7/64. shapely doesn't offer windows installers on their pypi page, even though they seem to have recently (github issues 104 and 109 -- i don't have the rep to post links. their pypi page, and their README say to use chris gohlke's unofficial binaries. i'm not clear on the reason -- something like pypi can't install dll's, so you have to make an installer by hand if your code depends on a dll, but making the installer is a pain because you need ms visual studio or something?
anyway, gohlke's binary works fine for me in winpython (2.7), but not when i try to import using matlab's new python bridge. shapely is the only python library on windows that is giving me this trouble in matlab -- i can use openCV, numpy, scipy, scikit's, mosek, picos, PIL, future, all fine. it's also the only library for which i need gohlke's installer. so i think there is a connection.
when i py.importlib.import_module('shapely') in matlab, i get this:
PyException with properties:ExceptionObject: [1x3 py.tuple] identifier: 'MATLABythonyException' message: 'Python Error: [Error 1114] A dynamic link library (DLL) initialization routine failed' cause: {} stack: [1x1 struct]a popup also comes up:
Microsoft Visual C++ Runtime LibraryR6034 "an application has made an attempt to load the c runtime library incorrectly"googling this, i get msdn article ms235560
here are some more things i've tried.
in matlab:
>> x=py.ctypes.util.find_library('geos_c')x = Python NoneType with no properties. Nonebut same in python!
>>> from ctypes.util import find_library>>> print find_library('geos_c')Nonehowever, i can use shapely from python:
>>> from shapely.geometry import MultiPolygon, Polygon, Point>>> Point()in matlab:
>> x=py.ctypes.CDLL('C:\Users\nlab\Downloads\WinPython-64bit-2.7.9.5\python-2.7.9.amd64\Lib\site-packages\shapely\DLLs\geos_c.dll')x = Python CDLL with no properties. >> x.GEOSversion()No appropriate method, property, or field 'GEOSversion' for class'py.ctypes.CDLL'.>> x.initGEOS()No appropriate method, property, or field 'initGEOS' for class 'py.ctypes.CDLL'.>> x=py.ctypes.CDLL('C:\Users\nlab\Downloads\WinPython-64bit-2.7.9.5\python-2.7.9.amd64\Lib\site-packages\shapely\DLLs\geos_c.dll').GEOSversion()No appropriate method, property, or field 'GEOSversion' for class'py.ctypes.CDLL'.Error: Unexpected MATLAB expression.>> x=py.ctypes.CDLL('C:\Users\nlab\Downloads\WinPython-64bit-2.7.9.5\python-2.7.9.amd64\Lib\site-packages\shapely\DLLs\geos_c.dll').initGEOS()No appropriate method, property, or field 'initGEOS' for class 'py.ctypes.CDLL'.Error: Unexpected MATLAB expression.>> py.dir(x)ans = Python list with no properties. ['_FuncPtr', '__class__', '__delattr__', '__dict__', '__doc__','__format__', '__getattr__', '__getattribute__', '__getitem__','__hash__', '__init__', '__module__', '__new__', '__reduce__','__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__','__subclasshook__', '__weakref__', '_func_flags_', '_func_restype_','_handle', '_name']in python:
>>> from ctypes import CDLL>>> x=CDLL("C:\\Users\\nlab\\Downloads\\WinPython-64bit-2.7.9.5\\python-2.7.9.amd64\\Lib\\site-packages\\shapely\\DLLs\\geos_c.dll")>>> print x>>> x.GEOSversion()-469489536>>> x.initGEOS()36606784>>> dir(x)['GEOSversion', '_FuncPtr', '__class__', '__delattr__', '__dict__', '__doc__', '__format__', '__getattr__', '__getattribute__', '__getitem__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '__weakref__', '_func_flags_', '_func_restype_', '_handle', '_name', 'initGEOS']a search for geos_c.dll just shows shapely's directory in my python's site-packages.
Visual Studio 2008. An application has made an attempt to load the C runtime library without using a manifest. This is an unsupported way to load Visual C++ DLLs. You need to modify your application to build with a manifest. Applications must use a manifest to load the C runtime library. For more information, see Visual C++ Libraries as Shared Side-by-Side Assemblies and Manifest Generation in Visual Studio. ... To correct this error Rebuild your application to include a manifest. Building an application with Visual Studio automatically puts the manifest into the resulting .exe or .dll file. If you are building at the command line, use the mt.exe tool to add the manifest as a resource. Use resource ID 1 if you build an .exe, and resource ID 2 if you build a .dll. For more information, see How to: Embed a Manifest Inside a C/C++ Application."
this seems to relate to chris gohlke's comment 35357436_23108273 at stack overflow question 23108273.
in matlab:
