I want to use Identify Task in ARCGIS API for android.I used this example and it works fine but when I try to change the URL to get data from another WMS it shows error here is my another wms I get error in folowing line
for (int index = 0; index < results.length; index++) { result_1 = results[index]; String displayFieldName = result_1.getDisplayFieldName(); Map attr = result_1.getAttributes(); for (String key : attr.keySet()) { if (key.equalsIgnoreCase(displayFieldName)) { resultList.add(result_1); } } } in this class which I have got from example
package com.esri.arcgis.android.samples.identifytask; import java.util.ArrayList; import java.util.List; import java.util.Map; import android.app.Activity; import android.app.ProgressDialog; import android.content.Context; import android.content.res.Resources; import android.graphics.Color; import android.os.AsyncTask; import android.os.Bundle; import android.view.Gravity; import android.view.View; import android.view.ViewGroup; import android.view.ViewGroup.LayoutParams; import android.widget.LinearLayout; import android.widget.ListView; import android.widget.TextView; import com.esri.android.action.IdentifyResultSpinner; import com.esri.android.action.IdentifyResultSpinnerAdapter; import com.esri.android.map.Callout; import com.esri.android.map.MapView; import com.esri.android.map.ags.ArcGISTiledMapServiceLayer; import com.esri.android.map.event.OnSingleTapListener; import com.esri.core.geometry.Envelope; import com.esri.core.geometry.Point; import com.esri.core.tasks.identify.IdentifyParameters; import com.esri.core.tasks.identify.IdentifyResult; import com.esri.core.tasks.identify.IdentifyTask; /** * This sample allows the user to identify data based on single tap and view the * results in a callout window which has a spinner in its layout. Also the user * can select any of the results displayed and view its details. The details are * the attribute values. * * The output value shown in the spinner is the display field. * */ public class Identify extends Activity { // create ArcGIS objects MapView mMapView = null; IdentifyParameters params = null; // create UI objects static ProgressDialog dialog; /** Called when the activity is first created. */ @Override public void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.main); // Retrieve the map and initial extent from XML layout mMapView = (MapView) findViewById(R.id.map); // add demographic layer to the map mMapView.addLayer(new ArcGISTiledMapServiceLayer(this.getResources() .getString(R.string.identify_task_url_for_avghouseholdsize))); // set Identify Parameters params = new IdentifyParameters(); params.setTolerance(20); params.setDPI(98); params.setLayers(new int[] { 4 }); params.setLayerMode(IdentifyParameters.ALL_LAYERS); // Identify on single tap of map mMapView.setOnSingleTapListener(new OnSingleTapListener() { private static final long serialVersionUID = 1L; @Override public void onSingleTap(final float x, final float y) { if (!mMapView.isLoaded()) { return; } // Add to Identify Parameters based on tapped location Point identifyPoint = mMapView.toMapPoint(x, y); params.setGeometry(identifyPoint); params.setSpatialReference(mMapView.getSpatialReference()); params.setMapHeight(mMapView.getHeight()); params.setMapWidth(mMapView.getWidth()); params.setReturnGeometry(false); // add the area of extent to identify parameters Envelope env = new Envelope(); mMapView.getExtent().queryEnvelope(env); params.setMapExtent(env); // execute the identify task off UI thread MyIdentifyTask mTask = new MyIdentifyTask(identifyPoint); mTask.execute(params); } }); } private ViewGroup createIdentifyContent(final List results) { // create a new LinearLayout in application context LinearLayout layout = new LinearLayout(this); // view height and widthwrap content layout.setLayoutParams(new LayoutParams(LayoutParams.WRAP_CONTENT, LayoutParams.WRAP_CONTENT)); // default orientation layout.setOrientation(LinearLayout.HORIZONTAL); // Spinner to hold the results of an identify operation IdentifyResultSpinner spinner = new IdentifyResultSpinner(this, results); // make view clickable spinner.setClickable(false); spinner.canScrollHorizontally(BIND_ADJUST_WITH_ACTIVITY); // MyIdentifyAdapter creates a bridge between spinner and it's data MyIdentifyAdapter adapter = new MyIdentifyAdapter(this, results); spinner.setAdapter(adapter); spinner.setLayoutParams(new LayoutParams(LayoutParams.MATCH_PARENT, LayoutParams.WRAP_CONTENT)); layout.addView(spinner); return layout; } /** * This class allows the user to customize the string shown in the callout. * By default its the display field name. * * A spinner adapter defines two different views; one that shows the data in * the spinner itself and one that shows the data in the drop down list when * spinner is pressed. * */ public class MyIdentifyAdapter extends IdentifyResultSpinnerAdapter { String m_show = null; List resultList; int currentDataViewed = -1; Context m_context; public MyIdentifyAdapter(Context context, List results) { super(context, results); this.resultList = results; this.m_context = context; } // Get a TextView that displays identify results in the callout. @Override public View getView(int position, View convertView, ViewGroup parent) { String LSP = System.getProperty("line.separator"); StringBuilder outputVal = new StringBuilder(); // Resource Object to access the Resource fields Resources res = getResources(); // Get Name attribute from identify results IdentifyResult curResult = this.resultList.get(position); if (curResult.getAttributes().containsKey( res.getString(R.string.NAME))) { outputVal.append("Place: " + curResult.getAttributes() .get(res.getString(R.string.NAME)).toString()); outputVal.append(LSP); } if (curResult.getAttributes().containsKey( res.getString(R.string.ID))) { outputVal.append("State ID: " + curResult.getAttributes() .get(res.getString(R.string.ID)).toString()); outputVal.append(LSP); } if (curResult.getAttributes().containsKey( res.getString(R.string.ST_ABBREV))) { outputVal.append("Abbreviation: " + curResult.getAttributes() .get(res.getString(R.string.ST_ABBREV)) .toString()); outputVal.append(LSP); } if (curResult.getAttributes().containsKey( res.getString(R.string.TOTPOP_CY))) { outputVal.append("Population: " + curResult.getAttributes() .get(res.getString(R.string.TOTPOP_CY)) .toString()); outputVal.append(LSP); } if (curResult.getAttributes().containsKey( res.getString(R.string.LANDAREA))) { outputVal.append("Area: " + curResult.getAttributes() .get(res.getString(R.string.LANDAREA)) .toString()); outputVal.append(LSP); } // Create a TextView to write identify results TextView txtView; txtView = new TextView(this.m_context); txtView.setText(outputVal); txtView.setTextColor(Color.BLACK); txtView.setLayoutParams(new ListView.LayoutParams( LayoutParams.MATCH_PARENT, LayoutParams.WRAP_CONTENT)); txtView.setGravity(Gravity.CENTER_VERTICAL); return txtView; } } @Override protected void onPause() { super.onPause(); mMapView.pause(); } @Override protected void onResume() { super.onResume(); mMapView.unpause(); } private class MyIdentifyTask extends AsyncTask { IdentifyTask task = new IdentifyTask(Identify.this.getResources() .getString(R.string.identify_task_url_for_avghouseholdsize)); IdentifyResult[] M_Result; Point mAnchor; MyIdentifyTask(Point anchorPoint) { mAnchor = anchorPoint; } @Override protected void onPreExecute() { // create dialog while working off UI thread dialog = ProgressDialog.show(Identify.this, "Identify Task", "Identify query ..."); } protected IdentifyResult[] doInBackground(IdentifyParameters... params) { // check that you have the identify parameters if (params != null && params.length > 0) { IdentifyParameters mParams = params[0]; try { // Run IdentifyTask with Identify Parameters M_Result = task.execute(mParams); } catch (Exception e) { e.printStackTrace(); } } return M_Result; } @Override protected void onPostExecute(IdentifyResult[] results) { // dismiss dialog if (dialog.isShowing()) { dialog.dismiss(); } ArrayList resultList = new ArrayList(); IdentifyResult result_1; for (int index = 0; index < results.length; index++) { result_1 = results[index]; String displayFieldName = result_1.getDisplayFieldName(); Map attr = result_1.getAttributes(); for (String key : attr.keySet()) { if (key.equalsIgnoreCase(displayFieldName)) { resultList.add(result_1); } } } Callout callout = mMapView.getCallout(); callout.setContent(createIdentifyContent(resultList)); callout.show(mAnchor); } } } and this is error
06-11 19:01:21.384 18989-18989/com.tehranuni.hazard.hazard E/AndroidRuntime
