How does gdal_calc numpy operators work?
Gdal_calc manual
Gdal_calc is introduced as :
gdal_calc.py - Command line raster calculator with numpy syntax gdal_calc.py [-A ] [--A_band] [-B...-Z filename] [other_options] OPTIONS: --calc=CALC calculation in gdalnumeric syntax using +-/* or any numpy array functions (i.e. logical_and()) DESCRIPTION Command line raster calculator with numpy syntax. Use any basic arithmetic supported by numpy arrays such as +-*/ along with logical operators such as >. EXAMPLE add two files together gdal_calc.py -A input1.tif -B input2.tif --outfile=result.tif --calc="A+B" average of two layers gdal_calc.py -A input.tif -B input2.tif --outfile=result.tif --calc="(A+B)/2"` set values of zero and below to null gdal_calc.py -A input.tif --outfile=result.tif --calc="A*(A>0)" --NoDataValue=0 Unexpected results
I made some good uses of gdal_calc in the past, yet, recent results makes no sences to me. I have 3 input files hillshades_A.tmp.tif, hillshades_B.tmp.tif, hillshades_C.tmp.tif and one output composite.tif. I want to make calculations with these inputs. I will follow pixel x=10 y=10 with values are A=222, B=220, C=224 to check the correctness of the output. Let's start.
Example:
# ASSIGN VALUE. Expect: 300. $gdal_calc.py -A ./hillshades_A.tmp.tif --outfile=./composite.tif \ --calc="300" --NoDataValue=-1 $gdallocationinfo ./composite.tif 10 10 -valonly >255 # Ergh? Ok, as it's a grey scale [0-255], such auto-correction is ok Then the fun start !
# SUM: A+B or (A+B), when A=222, B=220. Expect: 442 or 255. gdal_calc.py -A hillshades_A.tmp.tif -B hillshades_B.tmp.tif --outfile=./composite.tif \ --calc="(A+B)" --NoDataValue=-1 $gdallocationinfo ./composite.tif 10 10 -valonly >186 # Ergh? This is A+B-256=442-256=186 # AVERAGE: (A+B)/2, when A=222, B=220. Expect: 221 or 255. gdal_calc.py -A hillshades_A.tmp.tif -B hillshades_B.tmp.tif --outfile=./composite.tif \ --calc="(A+B)/2" --NoDataValue=-1 $gdallocationinfo ./composite.tif 10 10 -valonly >93 # Ergh? ok, per previous 186/2=93. # must use (A/2)+(B/2) => 221 # MULTIPLY: A*B, when A=222, B=220. Expect: 48840 or 255 gdal_calc.py -A hillshades_A.tmp.tif -B hillshades_B.tmp.tif --outfile=./composite.tif \ --calc="A*B" --NoDataValue=-1 $gdallocationinfo ./composite.tif 10 10 -valonly >200 # Ergh? ok, it's modulo: 222*220 % 256=200 # MULTIPLY+SCALE BACK: A*B/255, when A=222, B=220. Expect: 191.5 rounded to 191 or 192. gdal_calc.py -A hillshades_A.tmp.tif -B hillshades_B.tmp.tif --outfile=./composite.tif \ --calc="A*B/255" --NoDataValue=-1 $gdallocationinfo ./composite.tif 10 10 -valonly >0 # Ergh? Maybe A*B/255=200/255 (per previous point) being
