I am attempting to get a nice KML for simple review of POI/geocoding from a CSV. I a using ogr2ogr and a vrt. You can see the vet file below, with two attempts to get this right.
Basically, the issue is using ogr2ogr -f KML ... with the vrt w/o renaming results in a lot of "SimpleData" tags in the KML.
I'd like to get some CSV fields as the KML Placemark "Name" and "Description", concatenated fields, actually. -dsco NameField=RegionName option in ogr2ogr, but I don't see a way to concatenate fields into name, e.g Street, City, State..
In the .vrt below, the SrcSQL field results in no records. It does open, but with layer info. The Field tag (when not commented out) does result all records with in the new alias, but the "name" is the only field that comes through, it drops all other fields. Further, is there a way to concatenate fields using ?
Of course, perhaps ogr is not capable of concatenation ...
Thanks for any help!
wr
roofing-poi2.csv wkbPoint WGS84 SELECT StreetAddress as name
wr
