We have data being represented by the colormap copied below. I need to use env variables to change the hard coded color steps into whatever's input to the url parameters. I know you can use to pull variable values out of the url but I'm not really sure how to use that to replace the hard coded values. The colors aren't changing, just the quantity values. The getMap url would have something like &env=step1:1.0;step2:1.5; etc...
1 I tried doing what http://docs.geoserver.org/latest/en/user/styling/sld-reference/rastersymbolizer.html suggested by using
but that didn't work. Geoserver throws
So the CQL expression didn't seem to work as I hoped. How do I get that to work or use the ogc function?
IllegalArgumentexception: Argument "quantityString" should not be null.
Which makes sense.
