I have two datasets with positions that I need to compare. One would be the "observed" positions (someone took the GPS positions manually) and the other one was calculated using a software. To use statistical terms, I will call the latter one the "estimated" positions. These two dataset mostly overlap, but plotting both datasets is not enough, I need to conduct some kind of statistical analysis to show the results.Can anyone suggest a tool in ArcMap that I could use for this purpose?From what I have seen so far, most Spatial Statistics tools only work with densities, but they don´t seem to be applicable for track datasets.
