How do I set the domain extents to default?
I have a feature class that seems to be cutting off geometry. I looked around to see if there is a bounding box applied and found the Domain, Resolution and Tolerance tab in the Feature Class Properties.
The Min / Max values are populated with values that are not appropriate for my region. How do I set / reset the extents to the default value? That is, how do I let the geometry control the extents? Various documents suggest using the "use default extents" checkbox but I don't see that option anywhere.
This feature class is in enterprise SDE - not a local file geodatabase.
