I'm using DotSpatial to aid in processing some geospatial data. I'm using the code below to determine if a point (lat/lon location) is within a polygon contained in the SHP. If the point is in a polygon, I want some of the attributes stored in the DBF associated with the polygon. How do I access the attribute data?
// Reproject the strange shapefile so that it is in latitude/longitude coordinates wierdShapefile.Reproject(DotSpatial.Projections.KnownCoordinateSystems.Geographic.World.WGS1984); // Define the WGS84 Lat Lon point to test Coordinate test = new Coordinate(longitude, latitude); foreach (Feature f in wierdShapefile.Features) { Polygon pg = f.BasicGeometry as Polygon; if (pg != null) { if (pg.Contains(new Point(test))) { ****************************************** *** Need to access attribute data here *** ****************************************** // If the point is inside one of the polygon features return true; } } else { // If you have a multi-part polygon then this should also handle holes I think MultiPolygon polygons = f.BasicGeometry as MultiPolygon; if (polygons.Contains(new Point(test))) { return true; } } } return false; }
