How do I keep the OID field when exporting to csv?
I am having trouble with what seems like a simple task, so I need some help.
I imported a csv file and converted it to gdb format, and now I want to export it back to csv.
The file will be the exact same as before I imported it, except I want to keep the Arc Map generated OID.
However, when I export the file to csv, the OID field is lost, and contains null values only.
I understand why this is the case, because the OID is a temporary variable I guess.
Is there anything I can do to keep it though? Perhaps duplicate the field, but I am not sure how to do that in Arc Map.
