I have a table in a geodatabse which contains coded domain values.
I also have a feature class in the same geodatabase where I'd like to load those domain values.
There are hundreds of codes so I want to automate this process.
I've looked at the docs for Table To Domain to no avail. The issue is that after I run Table To Domain and select to output to the geodatabase of interest, I don't know what to do next. The result of running the tool seems to be nothing.
Is there anyway to load the coded values from a table (or an excel spreadsheet) into the domains of a feature class? You can see a sample of my workflow below.
