I'm trying to run the Watershed Segmentation algorithm, specifically, but I have been receiving the same error message using any of the available segmentation algorithms. I'm new to QGIS and have been running it in OSX 10.9.
The error message I receive says:
Any help, including links to resources addressing this error message would be much appreciated.
Oooops! The following output layers could not be open Output vector file: /var/folders/mq/01l7wc357319d3bxlsfp8n840000gn/T/processing/606c5f7baef84d2c9d91b5fc023a5947/-mode vector -mode.vector.out.shp The above files could not be opened, which probably indicates that they were not correctly produced by the executed algorithm Checking the log information might help you see why those layers were not created as expected
After checking the log, the OTB execution console output says:
OTB execution console output Segmentation -filter watershed -in /Volumes/New Volume/Thesis/soterra_LCmap/soterra_mosaic -filter.watershed.threshold 0.01 -filter.watershed.level 0.1 -mode.vector.inmask /Volumes/New Volume/hancockseg/hancockrst/hancockmask.shp -mode.vector.stitch true -mode.vector.minsize 1 -mode.vector.simplify 0 -mode.vector.layername layer -mode.vector.tilesize 1024 -mode.vector.startlabel 1 -mode.vector.outmode ulco -mode vector -mode.vector.out /var/folders/mq/01l7wc357319d3bxlsfp8n840000gn/T/processing/606c5f7baef84d2c9d91b5fc023a5947/-mode vector -mode.vector.out.shp
ERROR: option -mode.vector.out.shp does not exist in the application.
I'm really at a loss as to how I can overcome this issue. As I said, I'm new to QGIS and don't have any experience with open source GIS/RS software in general. My experience has mostly been with ESRI, ERDAS, and IDRISI. I'm very interested in performing some basic segmentation and classification but with a very specific goal in mind which I doubt I could accomplish using the Semi-Automatic Classification Plugin. I'm tempted to give it a try.ERROR: option -mode.vector.out.shp does not exist in the application.
