The following code adds a circle of given radius to the graphics layer on an ArcGIS map. How can i add a line that joins center of the circle to any point on the circle to the graphics layer.
Basically the question is how do i calculate a point on the circle, draw a line that joins the center to the point on the circle and add it to the graphics layer.
performSearchPoint : function(e) { var self = this; var radius = $('#radius-distance').val(); if(radius > 0 && radius < 100000){ $('#besideMouse').removeClass('hide'); $('#besideMouse').show(); var loadingBMint = setInterval(this.loadingBM, 0); var searchPointClick = OURAPP.App.Map.on("click",function(evt) { loadingBMint = clearInterval(loadingBMint); $('#besideMouse').hide(); var radius = $('#radius-distance').val(); var units = $("input:radio[name='unitsGroup']:checked").val(); if (units == "miles"){ units = "9035"; // if we use GeometryService } else { units = "9003"; // if we use GeometryService } //clear only search graphics for ( var gr in OURAPP.App.Map.graphics.graphics) { if(OURAPP.App.Map.graphics.graphics[gr].infoTemplate != null){ var template = OURAPP.App.Map.graphics.graphics[gr].infoTemplate; if(template != "undefined" || template != null){ if(template.title.trim() == "Search Graphic"){ OURAPP.App.Map.graphics.remove(OURAPP.App.Map.graphics.graphics[gr]); } }}} /*do buffer geometry for draw circle and use the circle geometry to get the features*/ var geoService = new OURAPP.esri.GeometryService("http://XXXX:YYYY/arcgis/rest/services/Utilities/Geometry/GeometryServer"); var params = new OURAPP.esri.BufferParameters(); params.geometries = [ evt.mapPoint ]; params.distances = [ radius ]; params.unit = units; params.bufferSpatialReference = OURAPP.App.Map.spatialReference; params.outSpatialReference = new OURAPP.esri.SpatialReference(4326); var bufferPolygon = new OURAPP.esri.Polygon; bufferPolygon.spatialReference = new OURAPP.esri.SpatialReference(4326); geoService.buffer(params,function(geometries) { var symbol = new OURAPP.esri.SimpleFillSymbol() .setColor(null).outline.setColor("red"); dojo.forEach(geometries,function(geometry) { geometry.spatialReference = new OURAPP.esri.SpatialReference(4326); var graphic = new OURAPP.esri.Graphic(geometry,symbol); // add name to identify the search graphics var template = new OURAPP.esri.InfoTemplate(graphic.geometry); template.setTitle("Search Graphic"); template.setContent("Map Query circle with Radius: " + radius); graphic.setInfoTemplate(template); OURAPP.App.Map.graphics.add(graphic); bufferPolygon = geometry; OURAPP.App.Map.setExtent(graphic.geometry.getExtent().expand(2)); }); self.searchType="Distance Search from point"; self.nameofplace=radius + " "+$("input:radio[name='unitsGroup']:checked").val(); self.showCount(bufferPolygon); }); searchPointClick.remove(); }); } },
