I am trying to pull layers from the glocal ocean circulation model Hycom. Before I go writing code to try to do this, is there a way to pull a single z depth as a geotiff?
e.g. I have hycom_glb_911_2015093000_t000_uv3z.nc. gdalinfo (gdal pre 2.1.0) reports:
gdalinfo hycom_glb_911_2015093000_t000_uv3z.nc Driver: netCDF/Network Common Data Format Files: hycom_glb_911_2015093000_t000_uv3z.nc Size is 512, 512 Coordinate System is `' Metadata: NC_GLOBAL#classification_authority=not applicable NC_GLOBAL#classification_level=UNCLASSIFIED NC_GLOBAL#Conventions=CF-1.0 NAVO_netcdf_v1.0 NC_GLOBAL#distribution_statement=Approved for public release. Distribution unlimited. NC_GLOBAL#downgrade_date=not applicable NC_GLOBAL#field_type=instantaneous NC_GLOBAL#history=archv2ncdf3z NC_GLOBAL#institution=Naval Oceanographic Office NC_GLOBAL#source=HYCOM archive file Subdatasets: SUBDATASET_1_NAME=NETCDF:"hycom_glb_911_2015093000_t000_uv3z.nc":water_u SUBDATASET_1_DESC=[1x40x2001x4500] eastward_sea_water_velocity (16-bit integer) SUBDATASET_2_NAME=NETCDF:"hycom_glb_911_2015093000_t000_uv3z.nc":water_v SUBDATASET_2_DESC=[1x40x2001x4500] northward_sea_water_velocity (16-bit integer) Corner Coordinates: Upper Left ( 0.0, 0.0) Lower Left ( 0.0, 512.0) Upper Right ( 512.0, 0.0) Lower Right ( 512.0, 512.0) ncdump:
ncdump -h hycom_glb_911_2015093000_t000_uv3z.nc netcdf hycom_glb_911_2015093000_t000_uv3z { dimensions: lat = 2001 ; lon = 4500 ; depth = 40 ; time = UNLIMITED ; // (1 currently) variables: double time(time) ; time:long_name = "Valid Time" ; time:units = "hours since 2000-01-01 00:00:00" ; time:time_origin = "2000-01-01 00:00:00" ; time:calendar = "gregorian" ; time:axis = "T" ; time:NAVO_code = 13 ; double tau(time) ; tau:long_name = "Tau" ; tau:units = "hours since analysis" ; tau:time_origin = "2015-09-30 00:00:00" ; tau:NAVO_code = 56 ; double depth(depth) ; depth:long_name = "Depth" ; depth:standard_name = "depth" ; depth:units = "m" ; depth
ositive = "down" ; depth:axis = "Z" ; depth:NAVO_code = 5 ; double lat(lat) ; lat:long_name = "Latitude" ; lat:standard_name = "latitude" ; lat:units = "degrees_north" ; lat
oint_spacing = "even" ; lat:axis = "Y" ; lat:NAVO_code = 1 ; double lon(lon) ; lon:long_name = "Longitude" ; lon:standard_name = "longitude" ; lon:units = "degrees_east" ; lon:modulo = "360 degrees" ; lon:axis = "X" ; lon:NAVO_code = 2 ; short water_u(time, depth, lat, lon) ; water_u:long_name = "Eastward Water Velocity" ; water_u:standard_name = "eastward_sea_water_velocity" ; water_u:units = "m/s" ; water_u:_FillValue = -30000s ; water_u:missing_value = -30000s ; water_u:scale_factor = 0.001f ; water_u:add_offset = 0.f ; water_u:NAVO_code = 17 ; short water_v(time, depth, lat, lon) ; water_v:long_name = "Northward Water Velocity" ; water_v:standard_name = "northward_sea_water_velocity" ; water_v:units = "m/s" ; water_v:_FillValue = -30000s ; water_v:missing_value = -30000s ; water_v:scale_factor = 0.001f ; water_v:add_offset = 0.f ; water_v:NAVO_code = 18 ; // global attributes: :classification_level = "UNCLASSIFIED" ; :distribution_statement = "Approved for public release. Distribution unlimited." ; :downgrade_date = "not applicable" ; :classification_authority = "not applicable" ; :institution = "Naval Oceanographic Office" ; :source = "HYCOM archive file" ; :history = "archv2ncdf3z" ; :field_type = "instantaneous" ; :Conventions = "CF-1.0 NAVO_netcdf_v1.0" ;
