How can I get ArcMap 10.2 to recognize a csv column as float and not int?
I am importing a .csv file (2 columns, 291 rows) into ArcMap 10.2 using ArcCatalog 10.2 to drag the .csv into ArcMap. The second column of the .csv is a floating point number (range is [0-1]), however Arc is treating that column as an int. That is: I can view the column as numeric with decimal places in Excel, text editor, etc., but when I open the table in ArcMap the column is reduced to 0, 1 or null. All non integers are replaced to null.
How to I ensure that Arc reads the column as a float?
I have tried the following, but none have worked:
  1. Re-ordering the observations so that observations with decimals are in the first eight rows (since I believe Arc looks at the first eight rows to determine data type).
  2. Editing the scheme.ini file to indicate column 2 has the datatype float. (But I may not be doing this correctly.)
  3. Saving the .csv file with an alternative delimiter.
  4. Changing the column in Excel from numeric to text. Changing the numeric column in Excel to different numbers of places after the decimal.
