I'm trying to merge the polygons (administrative boundaries) in a dataset untill they reach a minimum value. Lets say that the polygon dataset consists of the number of people per polygon and I need each polygon to contain at least 100 people. In that case I want the polygons with a value less than 100 to merge with an adjecent polygon, preferably in this order:
I'm using ArcMap 10.2.1. I already tried the dissolve tool, but this doesn't have the option to dissolve based on a minimum value. I saw that during an edit session in ArcMap you can merge polygons manually, but I found no way to do this in a model or a python script. If necessary I'm open to use other tools such as QGIS or spatialite.
Any thoughts or other approaches are more than welcome!
Cheers!
Mark
- merge polygon with one adjecent polygon that contains less than 100 people
- if adjecent polygons of less than 100 people are not available, merge with a polygon that contains 100 or more people.
- if after the merge the minimum number is not reached yet, repeat the process untill no more adjecent polygons are available.
- The end result should be a polygon dataset in which as many polygons as possible have at least 100 people per polygon.
Cheers!
Mark
