I am following below process.
1 - Setting
You must install a MySQL driver before doing anything. Unlike PHP, only the SQLite driver is installed by default with Python. The most used package to do so is MySQLdb but it's hard to install it using easy_install.For Windows user, you can get an exe of MySQLdb.
2 - Usage
After installing, reboot. This is not mandatory, but will prevent me from answering 3 or 4 other questions in this post if something goes wrong. So please reboot.
Then it is just like using another package :
!/usr/bin/python
import MySQLdb
db = MySQLdb.connect(host="localhost", # your host, usually localhost user="john", # your username passwd="megajonhy", # your password db="jonhydb") # name of the data base
you must create a Cursor object. It will let
you execute all the queries you need
cur = db.cursor()
Use all the SQL you like
cur.execute("SELECT * FROM YOUR_TABLE_NAME")
print all the first cell of all the rows
for row in cur.fetchall() : print row[0]
Of course, there are thousand of possibilities and options; this is a very basic example. You will have to look at the documentation. A good starting point.
But it will give me error :
Couldn't load plugin Importtool due to an error when calling its classFactory() methodTraceback (most recent call last):
File "C:/PROGRA~1/QGISWI~1/apps/qgis/./python\qgis\utils.py", line 219, in startPlugin plugins[packageName] = package.classFactory(iface)
File "C:/Users/n/.qgis2/python/plugins\Importtool__init__.py", line 34, in classFactory from .Import_tool import Importtool
File "C:/PROGRA~1/QGISWI~1/apps/qgis/./python\qgis\utils.py", line 478, in _import mod = _builtin_import(name, globals, locals, fromlist, level)
File "C:/Users/n/.qgis2/python/plugins\Importtool\Import_tool.py", line 36, in import MySQLdb
ImportError: No module named MySQLdb
1 - Setting
2 - Usage
!/usr/bin/python
import MySQLdb
cur = db.cursor()
