How Can I change the projection of shapefile in Qgis?
I have a probleme with Qgis. I would like to change the projection of my shapefile, it's about caves in my country. The default projection is set to EPSG:3003, I want to change it to wgs84 EPSG:32632. When I do a reprojection file or I change projection in the properties mask I don't have the correct result. My problem is when I verify the coordinates they are not correct.
