How can I add grid lines to a print composition using pyqgis?
I'm writing a qgis plugin to create an image in the print composer of the current map. I can get the map rendered in the proper place with a frame of the right width, and I can get grid annotations rendered in the proper places and orientation, but I can't get the actual grid lines to render. Here is the code I'm using:
def createImage(self): # Initialize the composition object. mapRenderer = self.iface.mapCanvas().mapRenderer() composition = QgsComposition(mapRenderer) composition.setPlotStyle(QgsComposition.Print) composition.setPaperSize(483, 330) composition.setPrintResolution(300) # Initialize the map object. Allow a top margin of 10mm, a bottom # margin of 50mm, a left margin of 10mm, and a right margin of 10mm. mapOriginXMm = 10 mapOriginYMm = 10 mapWidthMm = 483 - 10 -10 mapHeightMm = 330 - 10 - 50 composerMap = QgsComposerMap(composition, \ mapOriginXMm, \ mapOriginYMm, \ mapWidthMm, \ mapHeightMm) composition.addItem(composerMap) # Create the frame around the map. composerMap.setFrameEnabled(1) pen = QPen() pen.setWidth(0.2) pen.setJoinStyle(Qt.MiterJoin) composerMap.setPen(pen) # Initialize the image object. dpi = 300 dpmm = dpi / 25.4 paperWidthPixels = int(dpmm * composition.paperWidth()) paperHeightPixels = int(dpmm * composition.paperHeight()) image = QImage(QSize(paperWidthPixels, paperHeightPixels), \ QImage.Format_ARGB32) image.setDotsPerMeterX(dpmm * 1000) image.setDotsPerMeterY(dpmm * 1000) image.fill(0) # Create the map grid. composerMap.setGridEnabled(True) composerMap.setGridIntervalX(500) composerMap.setGridIntervalY(500) composerMap.setShowGridAnnotation(True) composerMap.setGridAnnotationPrecision(0) composerMap.setGridStyle(QgsComposerMap.Solid) # Top composerMap.setGridAnnotationPosition(QgsComposerMap.OutsideMapFrame, \ QgsComposerMap.Top) composerMap.setGridAnnotationDirection(QgsComposerMap.Horizontal, \ QgsComposerMap.Top) # Bottom composerMap.setGridAnnotationPosition(QgsComposerMap.OutsideMapFrame, \ QgsComposerMap.Bottom) composerMap.setGridAnnotationDirection(QgsComposerMap.Horizontal, \ QgsComposerMap.Bottom) # Left composerMap.setGridAnnotationPosition(QgsComposerMap.OutsideMapFrame, \ QgsComposerMap.Left) composerMap.setGridAnnotationDirection(QgsComposerMap.Vertical, \ QgsComposerMap.Left) # Right composerMap.setGridAnnotationPosition(QgsComposerMap.OutsideMapFrame, \ QgsComposerMap.Right) composerMap.setGridAnnotationDirection(QgsComposerMap.Vertical, \ QgsComposerMap.Right) composerMap.setAnnotationFrameDistance(1) composerMap.setGridPenWidth(5.0) composerMap.setGridPenColor(QColor(0, 0, 0)) composerMap.setAnnotationFontColor(QColor(0, 0, 0)) composerMap.setGridBlendMode(QPainter.CompositionMode_DestinationOver) # Do the rendering. imagePainter = QPainter(image) paperRectMm = QRectF(0, \ 0, \ composition.paperWidth(), \ composition.paperHeight()) paperRectPixels = QRectF(0, 0, paperWidthPixels, paperHeightPixels) composition.render(imagePainter, paperRectPixels, paperRectMm) imagePainter.end() image.save("/opt/tmpPhotos/test.tif", "tif") Can anyone tell me what I'm missing?
