I was planning to use Pythons is_land function, to differentiate between land and sea. However, after some inspection, I have major concerns in the accuracy. I cant find anything about this in the documentation, so I hoped anyone here could help me.
I initiate the basemap with high resolution, and a low area thresh-hold to help differentiate:
map = Basemap(projection='merc', resolution = 'h', area_thresh=0.001)When I try this function, It returns true even though I choose points clearly not on land:
>>> map.is_land(39.784004,3.345337)True>>> map.is_land(39.789808,3.3395)True>>> map.is_land(39.799041,3.332291)True>>> map.is_land(39.863371,3.346367)TrueThe three last ones is out at sea.
Anyone here that has used this function, and maybe got some tips to how I can make it more accurate, or if there is some (preferably) python substitution, or other open source programmable solution to check if a number of points is at land or not.
