Hillshade transparent for plain areas
Normally, when you use a hillshade as a layover in ArcGIS, you set the transparency at 80% or so (in the Layer Properties, display settings). As a result, the underlying layers, for example land use, will display with a grey haze, even the plain areas. How do I get a Hillshade where plain areas (middle grey tones) will display as transparent?
