I am trying to process some raster files using python scripts in Qgis 2.20, and I have been having trouble finding any documentation on using raster calculator in scripts being run in the processing toolbox.
I am trying to use scripts to process weather data. I will need to recalculate values of cells in order to represent projected wind speeds at different heights and probable gusting speed. I am trying to use the raster calculator for this but have been having trouble. I was not able to easily find a function for the script, and after some digging through the python console I was able to find the saga:rastercalculator function. Documentation in the python console (obtained through alhelp()), say that the parameters are as follows. algorithm: raster calculator Grids formula Raster
I am trying to run a basic formula through the raster calculator to get it working, but am having no luck.
Is this even the right approach to recalculating grid values in a python script?
Here is the code:
#load and symbolize tiff ##[User scripts]=group ##input_raster=raster #Imports #======= from qgis.core import * from PyQt4.QtGui import * from PyQt4.QtCore import * from qgis.analysis import * import processing from processing.core.Processing import Processing #import Tiff fileName = input_raster fileInfo = QFileInfo(fileName) baseName = fileInfo.baseName() raster = QgsRasterLayer(fileName, baseName) raster.loadNamedStyle(r"C:\Users\Maximilian\Documents\School\AGRG\test.qml") # add map to display QgsMapLayerRegistry.instance().addMapLayer(raster) #recalculate values processing.Saga:RasterCalculator(raster, "(raster)*2/2",outraster) Here is the error:
Uncaught error while executing algorithm Traceback (most recent call last): Traceback (most recent call last): File "C:/PROGRA~2/QGISVA~1/apps/qgis/./python/plugins\processing \core\GeoAlgorithm.py", line 202, in execute self.processAlgorithm(progress) File "C:/PROGRA~2/QGISVA~1/apps/qgis/./python/plugins\processing\script\ScriptAlgorithm.py", line 252, in processAlgorithm exec script in ns File "", line 65 processing.Saga:RasterCalculator(raster, "(raster)*2/2",outraster) ^ SyntaxError: invalid syntax
Here is the code:
