Help with iGIS shapefile import
I am using iGIS for iPADWhen I try importing one particular shapefile it gives me an error(see attached pic) saying I have the wrong projection. It is the same one I use on my other 10shapefiles that load just fine.
I'm assuming it is something wrong with the shapefile since all the other ones work. I use the same process and rechecked it many times on all, this is the only one that gives me the error.
iGIS support has went dark. They are no help.
Any ideas??
Thanks in advance
